You Breaker would be for a 20A Circuit 7A output means the input would be around 14A so your closest would be 20A for 240v single phase
You could use the reactor but a Line Filter would do all you need for the VFD Drive Input Power and then it would not compromise the DMM Circuit which should be separate
Yes will post you the Parameters for your Spindle
