- compressor size for HSD es951
I am just getting a CNC router setup with an HSD ES951 spindle. To road test the spindle I have attached a small 24l compressor to the spindle, but the advertised 6.35cfm flow rate is too small to perform a tool change. I have the recommended pressures for the HSD spindle but not the air consumption. I need to purchase a new compressor, and need to know if it's up to the job. I would like a quiet compressor, so I'm looking at an 80L 8.9cfm compressor https://stokker.co.uk/collections/si...air-compressor. Could anyone advise on the suitability of this compressor.
- You may not post replies
- You may not edit your posts
Forum Rules
