Water cooled or air cooled spindle spec's needed for Parameters you need
R and T are you input power connections R being Hot / Live
For and DCM I don't see a relay on the Breakout Board for FWD and Ground check this with a meter to see if it switches On/Off, if it does not have a Relay then you will have to add a Relay between FWD and Ground
Vi and ACM Check to see if you have 0-10v output from AV and Ground on the Breakout Board
