Can a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
Results 1 to 15 of 15
Thread: Can a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
    Mar 2010
    Default Can a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
    Can a 2.2kw 20,000 RPM water cooled spindle be indexed and hold that position if geared 4:1 to an R8 spindle coupled with an encoder?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Can a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
    No, as someone already told you.
    UCCNC 2017 Screenset
    Activation process Johnboy251's Avatar
    Nov 2018
    Quote Originally Posted by allaces View Post
    In my experience, I’m pretty sure that the max allowable speed for the average encoder will be exceeded and I’m not sure that encoders exist for that rpm. How about a opto switch with a simple segmented rotor?
    JohnCan a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
    Sent from my iPad using Tapatalk
    Mar 2010
    ger21,
    I must have missed that answer... where is it and I'm very sorry about that!
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Johnboy251 View Post
    There would be not problem with the encoder they can go way beyond any speed he would be using it at
    Mactec54
    Nov 2018
    Ok Can a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
    20,000 rpm geared 4:1 = 5000 rpm as you say - no probs with that.Can a 2.2kw 20,000 RPM water cooled spindle be indexed if coupled to an encoder?
  7. #7
    Mar 2010
    With the encoder not being an issue... is there an easy way to brake and hold the R8 spindle position using the setup I described?
  8. #8
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Curious, what do you want to do?
  9. #9
    Jan 2005
    Not at all 5000 RPM is quite slow Encoders on the average AC servo run at 5,000 to 6,000 RPM and can go way above 20,000 RPM
    Mactec54
  10. #10
    Mar 2010
    Quote Originally Posted by he1957 View Post
    I have a few projects that I would like to use this idea on if I could get it to work... but first... a small CNC lathe with a custom R8 spindle which would be used for machining small shafts and being able to index the spindle for machining grooves, keyways, drill holes, etc... using live tooling.
  11. #11
    Jan 2005
    It's not about the Encoder that part is a none issue
    No you are not going to be able to use that motor to do any kind of positioning the 2.2Kw spindle motor has a minimum speed that you can run it at the normal is 6,000 RPM there are some that have a 3000 RPM minimum so would be impossible to position anything at those speeds, spindle orientation is normally done at around 3RPM
    Mactec54
  12. #12
    Mar 2010
    Thank you for that answer... I can now forget that idea and look at other more reasonable options.
  13. #13
    Dec 2013
    I don't know if this motor will index but it might be worth a look https://www.automationtechnologiesin...or-and-driver/
    This motor will index and turn 5000 RPM https://www.ebay.com/itm/201903367253
    Jim Dawson
    Sandy, Oregon, USA
  14. #14
    May 2013
    washington
    there is no intrinsic problem with using a cheap 2.2KW Chinese spindle for indexing..
    the problem is simply $$$ and time to setup a servo driver configured for an induction motor (a relatively inefficient one at that) to properly drive the motor.
    most servos are permanent magnet for two reasons: higher air gap flux density (more torque per volume) and far lower losses.
    a 1hp induction motor (regardless of rpm) might consume 1000 watts full load.. and 300 watts no load. and 500 watts simply delivering full load torque at zero rpm.
    a permanent magnet servo might consume 900 watts when delivering 1 hp to the shaft, and 100 watts no load at nominal rpm, and 250 watts when delivering full load torque at zero rpm. its also easier to dynamically control.
  15. #15
    Jan 2005
    Quote Originally Posted by Eldon_Joh View Post
    Dollars he does not have for his project, or he would of already been using a servo drive and motor, I'm not sure why you keep on posting something that is almost imposable to do
    Please show us where we can find one of these magical servo drives that you can be program to run a 400Hz Ac motor
    Mactec54
