HI guys first post here and im stuck.
just recieved my vfd and quite simply ive gone into every menu i understand and changed parameters to what i needs to be but when i press run it spins for a couple seconds at super low rpm then throws a error and i cant for the life of me figure out what else i need to change. Ill list specs below and link the manual for the vfd, if i could get anyones input?
Spindle
2.2kw/3ph square chinese spindle
400hz
6amps
220v
and the VFD is a folinn BD600
https://cononmotor.com.au/wp-content...600-Manual.pdf
at the moment id like to try and make it work standalone then ill try and intergrate it into mach4.
Hope that enough information for the minute and somone might be able to point me in the right direction
