Need Help! Dirise ES100 VFD with 1.5KW Water-cooled Spindle
Results 1 to 7 of 7
Thread: Dirise ES100 VFD with 1.5KW Water-cooled Spindle
    Registered snbinc's Avatar
    Feb 2019
    Default Dirise ES100 VFD with 1.5KW Water-cooled Spindle
    Hello,
    I would like to first off thank everyone for providing help with the problem I face.
    A few months ago I purchased a package (VFD and Spindle) as follows:
    Dirise ES100 VFD
    Manual: http://www.dirise.cn/forum/filesyste...xA0NbrCFj67qGw
    Model: DRS ES100-2S-1R5
    220V
    Single Phase
    10A
    Spindle:
    1.5KW Water-cooled
    220V
    400Hz
    5A
    I never received any parameter setup information and am afraid to just guess as I am told to make sure the setup is absolutely correct else I can damage the inverter/spindle.
    If anyone has a similar setup or can please provide some assistance.
    Thanks,
    SNB.
    Member mactec54's Avatar
    Jan 2005
    Default Re: Dirise ES100 VFD with 1.5KW Water-cooled Spindle
    Quote Originally Posted by snbinc View Post
    Hello,
    Dirise ES100 VFD
    220V
    Single Phase
    10A
    Spindle:
    1.5KW Water-cooled
    220V
    400Hz
    5A
    Thanks,
    SNB.
    Do or can you get a English VFD Manual, no problem once I have that to give you a Parameter list, I will try and find one
    Mactec54
    Feb 2019
    Sorry didnt realize it was a Chinese manual!
    Here is the english manual: http://www.dirise.cn/forum/filesyste...hyLG4gNmOGK4JM
    Feb 2019
    I also noticed that the VFD is rated for 300Hz while my motor is 400Hz, could this potentially limit the full power of my motor?
    Jan 2005
    Then this VFD is not suitable for your spindle it has to match the spindle Hz, see if the seller will change it for you
    Mactec54
    Feb 2019
    Understood, have a bigger problem then :-)
    Thank you for all your help!
  7. #7
    Jan 2005
    When you get it sorted I'm here to help you set it up even if it is a different VFD Drive manufacture
    Mactec54
