- Need Help!- GDZ143X133-9 4p, 9kw H1 ATC spindle grounding the bit ?
Re: GDZ143X133-9 4p, 9kw H1 ATC spindle grounding the bit ?
I don't think there's really a good way to reliably use a conductive touch plate with most spindles. The spindle (inner part with the taper,) is not consistently grounded to the frame of assembly. Simplest solution would be to get a mechanical height setter.
You shouldn't really need the height setter if you keep your tool table updated.
- You may not post replies
- You may not edit your posts
Forum Rules
