Originally Posted by
Wallied
Hey mactec. My VFD is the HY hy01d523b, and the settings are ones suggested by you in other threads, PD000 etc.
I found the source of the problem from a poor solder joint on the connector. After re-doing the joint the spindle works as intended. Funny, the water-cooled spindle is quieter to my ear than the vfd fan running two meters away.
By the way, I'm changing the rpm with the front panel pot, but the range of the pot only gets me from the lower limit to around 16k rpm instead of the full 24k. Do you happen to remember if the range can be adjusted, or should I just switch to the up/down button control?
