Need Help! Spindle not working
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Spindle not working
    Mar 2018
    Default Spindle not working
    My 110v 800w air cooled spindle will not spin. It's got less than 10hours of use. Is there a way I can bypass the VFD and power the spindle to prove that it's the spindle and not the VFD.?
    Member awerby's Avatar
    Apr 2004
    Default Re: Spindle not working
    I suppose you could borrow someone else's VFD, but no; you need an inverter to provide the 3-phase power the spindle actually runs on.
    Mar 2018
    Thanks, Kinda thought so. I was always going to upgrade to water cooled and I guess the time is now. Just hope it's the spindle. Unless there's a way to check out the VFD.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Does the VFD display appear to be working?
    Unplug the spindle, and check the resistance of the 3 wires to each other. You should get 3 identical readings.
    UCCNC 2017 Screenset
    Mar 2018
    Quote Originally Posted by FGS View Post
    I did a continuity check and that was fine and eliminates the wires.
    Mar 2018
    It's working. I reset the VFD PD013 = 8. Then reprogrammed the VFD. plugged it in and it works. The only explanation I can think of that there must have been a surge or something that screwed up the settings. It had been working for almost a year without incident.
  7. #7
    Member mactec54's Avatar
    Jan 2005
    When you said you plugged it in, plugging and unplugging could cause this problem if that is how you are using it, VFD Drives don't like to be unplugged to disconnect the power, and should never be used this way
    Mactec54
  8. #8
    Mar 2018
    My VFD is plugged into my control enclosure. It comes on when I power up the box.
  9. #9
    Jan 2005
    You mean wired in, you would not normally have a VFD Drive plugged in to anything, or at least it should not be plugged in
    Mactec54
  10. #10
    Mar 2018
    I'm not sure what you mean. It's a 110V VFD that came with a plug attached to it. I set up my electronics enclosure with a Gecko G540 a Mean Well 48V PS 14 gauge THHN on the AC side and 16 gauge on the DC side. I installed a receptacle for the VFD to plug into. It's been working for a year without incident until 2 weeks ago. After reprogramming the VFD all's well.
  11. #11
    Jan 2005
    The wire you used would be questionable ( construction wire) you have to take installations like this seriously, you are dealing with industrial components and have to be wired to code requirements
    Where did you buy a VFD Drive that already had the cable attached, this would not of been from the manufacture with a cable attached
    Mactec54
  12. #12
    Mar 2018
    I'm still having problems. It seems if I haven't used my CNC for a while the VFD loses the settings. So I'll reprogram it and see if that's the problem. I'm not sure what you mean by you shouldn't unplug and plug the VFD. Mine is wired into my control box and comes on when I turn on my control box, but how is that different than pulling the plug and switching it on and off?
  13. #13
    Jan 2005
    You need to post a photo of how you have it wired it does not sound like it has been done correctly when you put the Parameters in you can lock them in PD000=0 this will lock them in if your drive is not damaged
    Mactec54
  14. #14
    Mar 2018
    I think I get what you mean and I think because of unplugging the VDF causes it to lose memory, thus my need to reprogram it. My VFD came with a normal plus that I had to wire to the R S and ground. I'm just a hobbyist and may not use my CNC for a month or more. To let the VFD be on for that length of time seems a bit much, but I guess that's what needs to happen. I'm trying to set up my Z axis with a Makita 11/4 hp trim router. I'll see if this works. I've installed it, having to a little grinding for clearance. I haven't used it yet and am somewhat concerned about the distance of the Z travel. Oh well, I'll keep persevering. Thanks for all the help.
  15. #15
    Sep 2005
    Turning the power on and off to your VFD will not cause a problem. You should Never turn off the power going to the spindle motor when the VFD is powered up it will cause the VFD to fail. My guess the VFD is either programmed wrong or defective.
    My drive is not Chinese maybe that makes a difference as it does not lose the programing.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  16. #16
    Jan 2005
    Quote Originally Posted by wmgeorge View Post
    It does not matter what VFD Drive it is they don't like being plugged in and unplugged and should never be installed like this
    The problem is he is not turning the power off, he is unplugging it this by it's self is going to mess up the VFD or damage it, here is a snip from the VFD Drive manual
    Attached Thumbnails Attached Thumbnails Spindle not working-pluggin-unplugging-vfd-drive-png
    Mactec54
  17. #17
    Member handlewanker's Avatar
    Sep 2006
    In other words, you power the spindle down to zero with the VFD and then it can be switched off?
    As the man, said it would not be practical to leave a VFD plugged in to a mains supply unattended for any length of time as the mains can drop out any time even for a brief instant and that is a switch off/unplugging by anyone's interpretation.
    Thanks to Mac for the tip......I'm sure not many people, if any, switch a VFD off at the power point while it is in the running position...…….I would think that if the motor was turning when the VFD was unplugged the back EMF would do some mischief to the VFD......would a set of diodes on the output lines cure that problem?
    What happens if, during a run cycle, a breaker trips or you get a complete loss of power etc...…...like they do frequently in South Africa.....total blackout for hours at a time...….I would think that in that case a UPS would be highly recommended.
    Down here in OZ we have an earth leakage device on the mains power board that detects a leakage to earth, or your body if you contact the main wiring etc, and will immediately switch the power off before you can get zapped to bits......it acts if it detects even a few milliamps of an earth leakage.
    Ian.
  18. #18
    Jan 2005
    Quote Originally Posted by handlewanker View Post
    Ian.
    Quality VFD Drives can handle those kind of problems, ( like Power Loss ) but the cheaper VFD Drive can not and most will fail when this happens
    This is what a EStop did to one spindle from 24,000
    Attached Thumbnails Attached Thumbnails Spindle not working-burnt-spindle-png
    Mactec54
  19. #19
    Sep 2006
    I was under the impression that the Estop button cut all power to the machine.....how can a spindle winding be burnt out with no power present......looks like a water pump failure.
    Ian.
  20. #20
    ericks
    Guest
    All of our machines have guarding/safety devices. The operators use these guards to stop the machines. Every time they do that(hundreds of times a day) the drives are de-powered on load. We have very few failures....if a drive can't handle the occasional power down under load then it's not worth having. When i first tested the cheap Sako drive i made a point of testing it numerous times to see if it could handle being powered down under load, no problem
Spindle not working
Spindle not working
