The spindle in my 6040 cnc has stopped working. When I set it to manual mode & press start it sounds like its going to go but dosnt move. The numbers on the display keep going up to a certain point then a error message appears.
When doing this a couple of times i'v tried turning it with my hand & it is really stiff almost stuck solid then I turn it really hard & the motor starts turning & it picks up speed till the error appears on the screen then the spindle stops. What would cause this?
I have looked at posts on here & tried to reset the vfd which I think I have done correctly but it dosnt seem to help.
Has anyone came across this before?
Mactec54
The spindle turns freely when the power is off. I looked at a post that I think you helped someone out with settings.May be D000=0 by Default this will lock any Parameter Change
I tried to copy them but it dosnt seem to work.
I added them as: D000=400
D001=1 ()
D002=400
D003=400
D004=220
D009=400
D010=100
D011=10 ( Default=10 Adjustable Acceleration )
D012=10 ( Default=10 Adjustable Deceleration )
D031=0 ( Default=0 For Keypad use (1 ) for Remote Control )
(D031 May need to be set to 4 D031=4 Depending how your Control is being used)
D032=0 (Default May need to be set to 1 D032=1 Depending how your control is being used )
D033=0 ( For Keypad Stop ( 1 ) If Remote Control is being used )
D036=1
Then similar happened so I changed
D031, 32 & 33 =1
& still the same happened.
On the last attempt I did se the spindle turn ever so slightly & then it said error on the display screen.
Its so frustrating lol
Got it working in manual mode atlast. there was a couple of wires which the solder had broke inside the box. next task trying to figure out how to turn it on/off remotely. Getting it going in manual mode has gave me some motivation to try again. was feeling like nothing would work.
i'm struggling to upload a image for some reason. the vfd terminal has 11 ports.
AVI, +10, COM, FWD, REV, MI1, MI2, MI3, MI4, Mo1, +12.
When I opened the box up it had 3 wires connected. AVI (red wire) COM(black wire) & FWD (yellow wire).
Will keep trying to upload a image
I'm changing it to a dsp0501. Was trying to upload a wiring diagram but it just wont go. it had 2 options. one which just started & stopped the spindle & the other that let you control the speed.Will keep trying
What I was wondering was if I went for the wiring that would give the spindle speed control. Say I connected S0 to M1, S1 to M2, S2 to M3 & SP to FWD & COM. Have you any idea what I would need to change on the VFD to make this work?
It is correct the way it is wired, you may have to play with some of the VFD Parameters, but first you have to have a 0-10v coming out of the Breakout Board AVI and com are connected, if you are using Mach3 then it could be just some setting there that need to be set
These are the Parameters for the VFD to play with, but first check the output from the Breakout Board this Voltage needs to change with the speed you command you put in the control
Mactec54
Thanks again Mactec54. will give this a try tonight after work.
Tried the meter on m1, m2 & m3 & they were all reading 11v when the machine was idle (first turned on with no job sent to it).
Next i sent a job to it & hit start & there was no volatage at m1, m2, m3 & the spindle should have been at full power at speed number 8 on dsp.
Next i tried different speed settings. there are 8 speeds in total & nothing happened till i got to speed setting number 3 & the spindle started turning very slowly (reading 40 on the display & i was picking up 10v from m1)
Next i dropped the speed down to setting number 2 & the spindle slowed down to 30 on the display & there was a reading of 10v from m1 & m3
Next i went down to speed setting 1 & the spindle slowed down again to 20 on the display & there was 10v from m2 & m3.
I had the VFD settings as D031=1 D032=1 D033=1.
Mactec54
I tried changing setting on the dsp so I could just have the spindle starting & stopping as the job starts & stops. it works but the spindle rotates very slow. would you say this would be a easy fix. I was looking online & found a copy of the vfd manual last weekend & now I cant find it anywhere. I was thinking there might just be a small setting change that would make it kick in at a higher speed
Mactec54
Yes the spindle runs max speed on manual mode. there is a voltage coming out of the board going to the VFD drive when the machine is offline (no active job)
You can see here :
https://imaginierie.com/impression-3...brication-cnc/
