Yes the normal way to connect the 0-10v or 0-5v PWM direct to the VFD for the speed control the connection is VI and ACM for speed control
For On / Off relay switched FWD and DCM connection, this is just a switch connection
There are some Parameters and a Jumper that need to be set as well
