I'm refurbishing a machine that's equipped with a Colombo 5.5Kw spindle and a (now discontinued) Delta VFD (VFD075H23A)
Manual Here
The spindle/VFD were fine, but the rest of the electronics have all been replaced with a Mach3/ESS/PMDX setup driving Gecko servo drives, together with a PMDX-107 spindle interface that I've configured to control the VFD. For the most part it's all working, but there are spindle configuration issues I haven't been able to sort out I'm hoping for some help with.
Whenever I mess with the braking / ramp stop parameters I get behaviors I don't expect. I have a braking resistor installed and my preferred behavior is that when I stop the spindle it ramps quickly to a stop instead of coasting. But no matter how I configure things, it doesn't work. For the most part, when I enable "Ramp" and set the values to spin down quickly what I get instead is an interminable spin-down that I basically have to stop by unplugging the VFD.
I also saw a weird behavior where when I set up DC braking on spin down what I got instead was an odd brake pulsing during Run (ie: not stopping).
At this point it's all working fine with Coast to Stop, but I'd really like it to spin down more quickly. The manual describes the parameters but doesn't really give enough context that I know how they all work together. Can anyone give me a quick primer on what I ought to be doing to accomplish my goal?
-Ben
