Need Help! spindle vs vfd
Results 1 to 13 of 13
Thread: spindle vs vfd
    Activation process thewillow's Avatar
    Nov 2018
    Default spindle vs vfd
    Hi Everyone,
    I'm new here, an hobbyist with a chinese cnc 6040 with prt 1500w vfd. I've been making windsurfing fins from g11 and have run into a spot of strife. I recently ran into the holding mounts, not once but twice and noticed that now the spindle now has an unusual noise at a certain rev. I'm going to say that I've done a bearing or something similar. So, I thought it's time to replace the spindle with a slightly more powerful spindle (2.2kw) with an er20 chuck. My Question, which may appear obvious to most is, do I need to change the vfd (1.5kw) as well, or will the prt do the job?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: spindle vs vfd
    Yes, you do. You'll need a VFD rates for 2.2Kw or larger.
    UCCNC 2017 Screenset
    Nov 2018
    Ok, thanks for that ger21. I think I'll look for the same model as mine, or thereabouts.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by thewillow View Post
    What supply voltage are you using for your machine
    Mactec54
    Nov 2018
    240 volts. Aust. single phase
    Jan 2005
    what is your max supply amps you have for the 240v single phase supply, this will determine what size spindle you can run
    Mactec54
  7. #7
    Nov 2018
    Just had a look at the meter box and it's 63 amps on the main switch.The new spindle is 8A.
  8. #8
    ericks
    Guest
    Where in Aust are you?
  9. #9
    Nov 2018
    I'm in W.A, south of Perth. I've just decided that it's going to be cheaper to replace the spindle with a 1.5kw and flog the new 2.2kw. And I'll call it lesson learnt. should have done more homework.
  10. #10
    Jan 2005
    63A is your mains supply not what your wiring is for your power outlet
    You need to know what the outlet amperage you are connected to, the wiring of the outlet will have an amp rating this would need to be a minimum of 25Amps to run the 2.2Kw on your 240V single Phase supply Spindle they are 8/ 9amps 3 Ph
    A 2.2Kw VFD Drive needs to have a minimum supply of 25Amps to work correctly
    Attached Thumbnails Attached Thumbnails spindle vs vfd-single-phase-amperage-2-2kw-png
    Mactec54
  11. #11
    Nov 2018
    Thanks mactec54, I've got 40 amps in the shed. But, I think at this stage I'll sell the 2.2kw spindle and work with the 1.5 just purchased.
    New bearings should make a difference. Cheers
  12. #12
    Nov 2018
    Well, that was good news, as the seller hadn't sent the 2.2kw spindle, they did a refund. Very happy with thier business acumen.
  13. #13
    ericks
    Guest
    Good to hear they were so good
spindle vs vfd
spindle vs vfd
