mach3 BOB spindel direction
Results 1 to 4 of 4
Thread: mach3 BOB spindel direction
    Nov 2009
    switzerland
    Default mach3 BOB spindel direction
    Hello
    I have the a BOB for mach 3. In the manual there is nothing about the spindel direction. It is a 5 axis board. I need just 4 (X,Y,Z,A). Is it possible to use a pin for the 5 axis?
    Attached Thumbnails Attached Thumbnails mach3 BOB spindel direction-51j-kpktj2l-jpg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: mach3 BOB spindel direction
    unless you add another relay to the breakout board
    for example
    this is a dual relay that you could add ,
    mach3 BOB spindel direction-dual-relay-board-jpg
    the 2 relay board could be controlled by the "step" or "direction"
    outputs from an axis not being used to control a stepper motor
    alternatively a single add on relay could be controlled by pin 16
    the breakout boards onboard relay only provides on/off control of the spindle
    the analogue 0 to 10V DC output being used for speed control
    mach3 BOB spindel direction-ebay-cnc-bob-jpg
    what type of spindle speed control do you need to control ???
    most VFD manuals show how they can be controlled by 2 switches -
    one for forward and another for reverse
    the switches can be replaced by two relays for CNC control
    mach3 BOB spindel direction-cnc-vfd-connection-jpg
    John
    Last edited by john-100; 11-05-2018 at 03:49 PM. Reason: add CNC to VFD connection diagram
    Nov 2013
    do you have any left-hand cutting tools?
    When I started I thought I needed a bi-directional spindle but then never used it. I do have three lefthand drills for trying to get out broken bolts and things
    but I never use them in the mill.
    Craig
    Nov 2009
    switzerland
    Thanks a lot John. I have a syil with a smoked spindel controler. I don't get any spare parts from syil. I have a infranor servo controler and servor motor. That runs with a signal cc aud cl. For the speed I need 0-10V. The BOB is ok for that. I was not shure if I could use a output of a axis which I do not use.
