I have a similar (slightly older) motor in my lathe and am getting ready to replace it with a servo motor. The original Fanuc drive had to be connected to a Fanuc controller to generate the proper signals for the motor. I replaced the entire Fanuc system with my own and am currently running the spindle motor on a sensorless vector VFD. I am able to rigid tap but not index. But rigid tapping took some software gymnastics to make it work. The spindle is driving an external encoder that is connected to my controller. I have an encoder module for the VFD, but I haven't installed it yet. That is going to be the last try to get the spindle to index, I'll know in a week or so when I get time to work on it. If this fails, I will be replacing the motor with a 7.5KW servo.
I recommend looking for a servo motor that will meet your needs.
