Help with adding a spindle and vfd to controller
Results 1 to 10 of 10
Thread: Help with adding a spindle and vfd to controller
    purplepeopleeater's Avatar
    Sep 2018
    Washington
    Default Help with adding a spindle and vfd to controller
    Picked up a velox cnc machine that pretty much new, its a few years old and running a parallel box.
    Id like to move from a slow dc motor to a spindle but my controller doesn't support it, I am fairly green on messing with the electronic end of these, any help?
    Sent from my SM-G955U using Tapatalk
    Dec 2017
    Default Re: Help with adding a spindle and vfd to controller
    If you can not connect the vfd to your
    Controller it is not a big deal.
    just buy a vfd and spindle then you can turn it on manually by a switch and potentiometer for adjusting the rotary speed
    then you can run the gcodes
    After job is done then turn off the vfd from the switch.
    Best Regards,
    mattcnc@protonmail.com
    Sep 2018
    Washington
    I knew i couldn't, but wondered if there was a simpler breakout board i could use to do so.
    I think i can control speeds from vfd by changing frequencies, i think
    Quote Originally Posted by mattcnc123 View Post
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by purplepeopleeater View Post
    What control software are you using, and yes a simple Breakout Board that has PWM 0-10v output can do what you want depending on your control you are using
    Mactec54
    Sep 2018
    Washington
    What control software are you using, and yes a simple Breakout Board can do what you want depending on your control you are using
    Mach3, its a velox parallel controll box too
    Jan 2005
    Check your Breakout Board outputs you may already have a 0-10V PWM output and a spare relay for turning the VFD On/Off
    Mactec54
  7. #7
    Sep 2018
    Washington
    No spare relays inside unfortunately Help with adding a spindle and vfd to controller
  8. #8
    Dec 2017
    Where are you located ?
    if you want I can upgrade your velox cnc to new electronics
    then you can control the vfd from the software.
    email me your contacts.
    Best Regards,
  9. #9
    Sep 2018
    Washington
    Im pretty sure my BB just needs relay and control wire posts yes?
  10. #10
    Sep 2018
    Washington
    Im in Washington state, whats your email... sent one to the one listed in profile
