Originally Posted by
smwmachine
Hello all,
I have a YASKAWA CIMR-MT3 15K Spindle drive & I need some help. This machine has been down for three months. The spindle stopped mid run and gave alarm 10C (over-current) on the drive.
I am a small one man & wife shop and have been able to stay open for 20 yrs. due to fixing things myself. I'm no electronics person, but I've been able to get by with looking things over and testing what I can before having to spend big $ it's the only way I can keep things going these days. I find that just capacitors are usually to blame most often of the time, so I bought some high-end PACE brand solder and desoldering equipment. I have 3 Okuma twin turret live tool lathes & 1 KIA 21 lathe & it has this problem.
It blew the top IGBT #2DI200A-050P. This is the one controlled by CN9 & CN12 on the driver PCB. I found that the fan was not working and it was hot, so I replaced the two fans. I replaced the Module, and it ran for 1/2 a day then quite again with the same problem and alarms UV (under-voltage) 10C. It was not as hot as before, and the fans are working - temp meter says 90 deg. F. in the drive. I've tested all the caps and transistors on PCB's, and they are good or all nearly identical as per below.
I tested the following:
Meggered the motor all readings were good.
Thyristors 2M55DZ-H with DMM ohms across k1-g1 & k2-g2 all check 26-27 ohms except 1 of them is 19.
Thyristors 2M55DZ-H with 12v and light all checked good & functioning.
Transistors QM150E2Y-HD & QM150E3Y-HD with DMM diode mode all check as should.
IGBT the Top 1 straight short from C2E1 to E2 (same as 1st bad 1).
The software EPROMs are NSN000199L & NSN000199H it does not use a motor contactor.
Does anyone out there have info I could use to do some tests on the C343 PCB? It all looks brand new.
I replaced all the modules & diodes in the base & replaced all the caps & transistors etc. on the Drive PCB and caps on the CPU PCB. I run it at 200 rpm & it will reverse and seems o.k. at 200 rpm. The odd thing is when I take an amp reading on the R,S,T 210v input lines they do not read even R=3 amps, S=2.5 amps & T=1.5 amps. The output to the motor at U,V,W are all 5 amps at 200 rpms.
I have not replaced the reactor or breaking resistors they seem to check good.
Any advice is very much appreciated!!!! Thank you. Bill
