Looks like the MX4660 has a 0-10v output for spindle control on CN6, so that should be all that's needed (other than wiring and connectors to actually attach everything.)
Can someone give me an overview of what is needed to have speed control within MACH3 for one of these 2.2Kw chinese Hyuanyang spindle packages? I am helping a friend out on this one.
Are there any additional hardware components needed other than the spindle package and the Leadshine MX4660??...... A high level overview would be greatly appreciated on how to accomplish this
- New Machine Build- Mach3 VS G540 & A131 VFD "Spindle control in MACH3"
- Need Help!- Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
- Help chosing a spindle speed sensor to indicate spindle speed in mach3
- Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code
- Mach3 and VFD spindle
Are you helping Randy??
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
