Help with Chinese Spindle and C6 Board
Results 1 to 1 of 1
Thread: Help with Chinese Spindle and C6 Board
    Aug 2004
    Default Help with Chinese Spindle and C6 Board
    Hello Everyone
    I got a Smoothstepper ESS and a cnc4pc C6 board, Got it all hooked up and everything seams to work ok,
    I test the output, the voltage go up when i increase the speed and voltage go down when i decrees the speed
    Then i test the pot of the spindle like they say in the manual P1(Gnd) to P3 (reference voltage) I get 4.09 Volts P1 to P2(wiper) I get nothing
    I connect the P1 to gnd and P2 to the output of the C6 Board
    Here is the problem i am having
    with the spindle hooked up to the C6, i turn on the spindle in mach, it revs up a bit then stops, mach said it triggered a limit switch
    Everything run fine with the pot and i placed all the wiring at the same place to see if that make noise and everything is good
    It only stops when it is connected to the C6 Board
    Anyone have any idea ??
    Attached Thumbnails Attached Thumbnails Help with Chinese Spindle and C6 Board-motor-jpg
