Need Help! 800W Spindle with 2.2kw VFD - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: 800W Spindle with 2.2kw VFD
  1. #13
    Gold Member
    Jan 2005
    Default Re: 800W Spindle with 2.2kw VFD
    Quote Originally Posted by Goemon View Post
    That would suck. I take a lot of comfort from the ability to set my VFD not to output more than my spindle can handle.
    still, a 2.2kw VFD is not that much of a jump for an 800watt spindle. I'd be amazed (in a bad way) if it couldn't be set up with the appropriate limits for the spindle. My 7.5kw VFD can be set all the way down to .1a.
    You could use your 7.5Kw VFD to drive the 800w Spindle / Motor if you wanted to, and it would be completely safe
    Your VFD Drive amp minimum is only dependent on what model it is, by the spec's for the Huanyang GT they start at .8a all the way up to 6000a not .1a
    Mactec54
  2. #14
    Gold Member Jim Dawson's Avatar
    Dec 2013
    This would only be a problem when the VFD is rated much higher than the motor. For instance, I have a 1/2 hp grinder and I grabbed a 2 HP VFD off the shelf to power it up because that's what I had. I don't remember the exact numbers but as I recall, the minimum current setting was about 30% higher than the motor rating.
    Jim Dawson
    Sandy, Oregon, USA
