Spindle Cable from VFD Question
Results 1 to 4 of 4
Thread: Spindle Cable from VFD Question
    Registered robotintheforest's Avatar
    Jan 2018
    Winlaw
    Default Spindle Cable from VFD Question
    Hi if anyone can help, I have a machine running a 2.2kW HY spindle and it is using a 16 AWG 4C Shielded Cable (600v) and has been working fine for two years now. I am building a bigger machine and my supplier has run out and is not getting more and I am having trouble finding it in this rural area. However I am able to get 16 AWG 2C Shielded cable and I am wondering if a double run of this from the VFD would induce any problems?
    Luke
    Jun 2011
    Default Re: Spindle Cable from VFD Question
    Yes, you're likely to see noise issues by running your motor phases through 2 separate cables.
    You would be better off with 4 single conductor wires, twisting the 3 for the motor phases together, and running the ground along side them in some braid. Spindle wiring really should be shielded though, and that's tough to do without the proper cable.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by robotintheforest View Post
    Luke
    You can buy your cable from IGUS the cable you want is CF6-15-04
    They are in Canada if that is where you are, here is one contact in BC
    mobile:
    1-604-316-7607
    Fax:
    1-905-760-8688
    E-Mail:
    thopfner@igus.com
    Mactec54
    Jan 2005
    Quote Originally Posted by skrubol View Post
    Open braid is of not use what's so every for a VFD Drive installation, 3 tightly twisted wires would be better by them selves if he has no other options
    Mactec54
