- Need Help!- Spindle control in forwards
*Registered User*
Hi, Building myself a little router with the following parts and I'm having issues with the spindle control. I am running mach 4 also.
https://cnc4pc.com/2-2kw-vfd-motor-s...oller-vfd.html
https://cnc4pc.com/c11g-multifunction-cnc-board.html
Currently I can get the software to turn on the counter clockwise rotation but not the clockwise. I have wire the CW direction up to the relay as shown in the diagrams but when I click these it doesn't seem to do anything.
I'm not sure exactly what pin should be controlling this relay also. I believe it may be pin 14 but if I set that in the output on the mach 4 software to pin 14 it is always on and will run in forwards with the software enabled or disabled until I take the output off.
Any advice is appreciated and thanks for your help.
Best Regards
Martyliketoparty
- You may not post replies
- You may not edit your posts
Forum Rules
