Need Help! What settings on Huanyang inverter to control rpm from software????
Results 1 to 20 of 20
Thread: What settings on Huanyang inverter to control rpm from software????
    May 2018
    Sweden
    Default What settings on Huanyang inverter to control rpm from software????
    Hello!
    I have a Huanyang HY01D523B, with a 1,5kw spindle.
    Im trying to set up the inververter that I can control the rpm from my CNC program Estlcam.
    I´ve been searching everywhere for info but I cant find any.
    I have connected everything as I think it should be: ACM (from inverter) to GND on controller card (Estlcam interface), and VI (from inverter) to 0-10v on the controller card.
    But what settings do I need to do on the inverter, to make it all work?
    See pics of interface and inverter terminal
    /Ola
    Sweden
    Attached Thumbnails Attached Thumbnails What settings on Huanyang inverter to control rpm from software????-img_9813-jpg   What settings on Huanyang inverter to control rpm from software????-img_9814-jpg
    Dec 2003
    Default Re: What settings on Huanyang inverter to control rpm from software????
    PD001 = 1 External terminal.
    Also close the FWD or REV PLC input.
    May 2018
    Sweden
    Quote Originally Posted by Al_The_Man View Post
    Thanks for reply.
    I’m not sure what you mean by close the FWD or REV PLC input
    Dec 2003
    The VFD has 6 multi function inputs operated by a contact closure to DCM (COM) they come with default settings but can be changed for up to 32 option settings.
    The default FWD/FOR is enable forward run mode.
    May 2018
    Sweden
    Not sure what contact closure means (language barrier). Is it when you connect a cable in between the two slots? I’m using the FOR slot for controlling spindle on/off.
    Dec 2003
    Contact closure means close the circuit - switch on - connect together etc.
    May 2018
    Sweden
    Ok. Thanks.
    Is it this what you mean? See pic.
    I tried that now, but nothing happened except that
    Now the control of spindle on/off didn’t work.
    Attached Thumbnails Attached Thumbnails What settings on Huanyang inverter to control rpm from software????-b95d868d-9d2b-4a20-9346-35d3f4a16c42-jpg
  8. #8
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by soilguitar View Post
    Ok. Thanks.
    Because you have to use a Switch or controlled Relay where the Jumper you added between the For and DCM
    What is the other white wire doing it should not be there in For
    So if you cut the Jumper Wire and put a Switch in the middle that will turn it On / Off if you have the parameters set correct
    Mactec54
  9. #9
    May 2018
    Sweden
    The on/off is connected through a relay on the controller card (white and black cable).
    It worked fine when I didn’t do any short cuts.
  10. #10
    Jan 2005
    You can't do the short cut, connect it back how you had it connected before
    Mactec54
  11. #11
    May 2018
    Sweden
    Ok. Done. See pic.
    DCM & FOR connected to relay on controller card.
    ACM & VI connected to GND & 0-10v to controller card interface.
    With connections, the spindle on/off is working. But not the rpm control.
    I tried all different parameter settings on pd001 and pd002.
    So what am I doing wrong here?
    Attached Thumbnails Attached Thumbnails What settings on Huanyang inverter to control rpm from software????-2aec5a2b-ae27-4c3e-8100-00c234d2a70a-jpg
  12. #12
    Dec 2003
    Try it purely manual, with a switch or link between DCM and FOR connect a 10k pot across VR, V1 (slider) & ACM.
    Jan 2005
    Ok. Done. See pic.
    IS your Breakout Board outputting 0-10v when you change the RPM in the control, just check it with a meter to see that it is working at the Breakout Board
    Mactec54
  14. #14
    May 2018
    Sweden
    Just got an email from Estlcam. He said the same thing. He also said, make sure you have 12v power supply to the interface card. I didn’t know about that. Estlcam don’t have any manuals or what so ever.
    Of course he didn’t write how to connect the power in the terminal.
    Guess I have to wait for another couple of days before he replies on that quest.
    Do you have any idea of how to connect the 12v? See pic.
    Attached Thumbnails Attached Thumbnails What settings on Huanyang inverter to control rpm from software????-2fb0570f-3985-4461-9689-f1ae98feaf5b-jpg
  15. #15
    Dec 2003
    The terminal strip pic does certainly does not indicate anything definitive.
    Why is there zero support on the product?
    I would be very reluctant to obtain anything with no manual or supports etc?
    May 2018
    Sweden
    I agree.
    Just got a reply from the manufacturer. See below.
    Maybe you’ll understand my frustration:
    “Hello,
    There should be Vin and GND for external power supply – but I do not manufacture or sell this interface – please ask the seller as I may not be up to date.”
  17. #17
    Jan 2005
    I agree.
    “Hello,
    So he is saying to connect to the terminals Vin and GND, which is in your photo, this will then supply your Breakout Board with the needed power for the PWM 0-10v Etc
    Attached Thumbnails Attached Thumbnails What settings on Huanyang inverter to control rpm from software????-vin-gnd-png
    Mactec54
  18. #18
    May 2018
    Sweden
    Yes.
    My bad. I thought he was referring to the VFD terminal.
    I tried this now but it still didn’t work. I’ll try to measure the 0-10v on the terminal.
  19. #19
    Jan 2005
    Yes.
    The output of the 0-10v on your Breakout Board would have to be setup in your control software as well, make sure this part is all working at the Board level
    Mactec54
  20. #20
    *Registered User* Lexluther35's Avatar
    Jan 2019
    Is it working? Rpm over estlcam?
    I think it is digital pin 5 on arduino.
