Need Help! Break out board - VFD - Mach 3 wiring
Results 1 to 7 of 7
Thread: Break out board - VFD - Mach 3 wiring
    *Registered User* Francohara's Avatar
    Jun 2018
    Default Break out board - VFD - Mach 3 wiring
    Feel a bit silly having to ask .... i'm sure it's been answered before if not here then in some other dark corner of the interwebs but just cant find the exact combination answer to suit.
    Most of the posts i have read through look like 50 shades of break out boards in term of types...
    I have by home build CNC up and running for a few months now. Cutting some nice wood projects but have just have the basics (x,y,z drives and limits) wired to the BOB. Been controlling the spindle manually (Huanyang inverter type) Now i feel it's time for some improvements and to add in touch probe and to control spindle the spindle via BOB and mach 3.
    Only thing is i cant figure out the wiring and afraid to blow stuff up now at this stage that my machine is up and running well.
    I have attached a pic of the same BOB as im using and a pic of the inverter.
    As i said on my BOB ... only x,y,z axis and limits are been used.
    Is the spindle connected to the A or B axis ?
    I see other BOBs where the spindle is connected to the relay but then where does the 0-10V signal for speed control connect to ? Confused.
    Appreciate any help
    Attached Thumbnails Attached Thumbnails Break out board - VFD - Mach 3 wiring-bob-1-jpg   Break out board - VFD - Mach 3 wiring-bob-2-jpg   Break out board - VFD - Mach 3 wiring-huanyang-inverter_1-jpg
    Dec 2003
    Default Re: Break out board - VFD - Mach 3 wiring
    If you have the VFD with the 'Modbus' type option you can use the Mach plug in to control it, you may need a COM port or USB adaptor depending on what your PC has.
    Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Gold Member
    Jan 2005
    Quote Originally Posted by Francohara View Post
    Appreciate any help
    Your Breakout Board does not have, that I could see a 0-10v PWM output, so this board can not control your spindle speed, it could start and stop the VFD with the Relay connected to DCM and For Terminal, you have to set the correct Parameters to use this also
    Attached Thumbnails Attached Thumbnails Break out board - VFD - Mach 3 wiring-dcm-png
    Mactec54
    Jun 2018
    Ah... that makes sense. ... I was looking for something that my Bob does not have. Can you get specific Bob for the spindle that run through rs232 or something ? The paralell is taken with my current board.
    Jun 2018
    Quote Originally Posted by Al_The_Man View Post
    Hi
    The manual mentions nothing about modbus only mentions rs485 communication (not sure if related ?)
    Gold Member
    Jan 2005
    Hi
    You do have Modbus, rs485 same thing, most likely your manual is not very clear about it, the plug in is needed that Al post
    On your VFD the connection would be R- and R+
    Mactec54
  7. #7
    Dec 2003
    Hi
    In this case, one and the same, although the Huanyang vary from standard Modbus, hence the work that had to go into the plug-in.
    Strictly speaking they are two different things Modbus is a form of data communication and RS485 is the hardware standard it is sent over, it could be RS232 if you wanted to,or?,
    For example, I use RS485 TX/RX IC's for encoder interface/driver,
