Your electrical installation should already have a fuse installed according to your local regulations. No need to add extra fuse, and definitely no fuse between the motor and the VFD. I would also advise you to read the VFD manual. To be honest, I think you should contact a local electrician who can help you out with this. You need also protective earth, otherwise that thing can kill you or somebody else.
