That doesn't give you any interference protection between stuff in that box. If you need to put some control electronics right next to that unshielded VFD you might see some issues as near-field radiation can be much worse than far-field radiation (far field drops off at the square of distance in open space, near field drops off much quicker usually.) Sticking a piece of grounded sheet metal or some sort of screen between power electronics and instrumentation can even make a big difference.
