Yes you can use it without any problems, bigger is always better, what you heard is by someone that does not know anything about VF Drives
Do you have the correct Parameters to set, the VFD Drive ??? this is important
Don't do a VFD Drive ReSet, this can cause problems when changing to the parameters that you need to set
What are the 2.2Kw Spindle spec's ???
