Need Help! HY VFD Wiring Label - Was it placed upside down ?
Results 1 to 14 of 14
Thread: HY VFD Wiring Label - Was it placed upside down ?
    Registered lucidgroove's Avatar
    Oct 2017
    Default HY VFD Wiring Label - Was it placed upside down ?
    Hey cnc experts! I picked up a 2.2 kw water cooled spindle with HY VFD from ebay back in November. I was still building out other parts of the machine and have just recently gotten to setting up the VFD. When I opened it up I noticed one of the strips of terminals has "maybe" an upside down label. All the images in the manual and what I have referenced online, show both strips with the labels from left to right. My thought was that it got put on backwards so I should wire into the terminals as if the sticker were on the other way. For example I am using the RS-485 connection method so I wired into the RS+ and RS-. But I did that on the far right, instead of the far left where the labels are. Here is a pic.
    Nameplate Description
    HY02D223B
    VFD 1 Phase/3 Phase AC 220V 50Hz/60Hz
    Spindle 3 Phase 0-220V AC 2.2KW 11Amps .50-400Hz
    HY VFD Wiring Label - Was it placed upside down ?-upside_down-jpg
    It seems to me that if is "As Designed" it would require a lot of PCB changes and then they would recreate the new label with correct orientation and order.
    Thanks!
    Attached Thumbnails Attached Thumbnails HY VFD Wiring Label - Was it placed upside down ?-upside_down-jpg
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: HY VFD Wiring Label - Was it placed upside down ?
    Just measure the resistance between FA and FB - those are normally closed relay contacts.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by lucidgroove View Post
    HY02D223B
    Thanks!
    It does appear to be incorrect, you may have a copy of the HY VFD, I have seen the label like this before
    Attached Thumbnails Attached Thumbnails HY VFD Wiring Label - Was it placed upside down ?-control-terminals-png   HY VFD Wiring Label - Was it placed upside down ?-control-terminal-png
    Mactec54
    Dec 2003
    Looks like typical Chinese quality control,!!
    I agree, it would have needed a change to the PC Board.
    You can confirm the 'backwards' label by checking continuity on the ACM and DCM between top and bottom row as they normally would be.
    Nov 2012
    Quote Originally Posted by Al_The_Man View Post
    ACM and DCM are very likely tied together inside the VFD. It is safer to check FA and FB as I suggested earlier - those would have no connection to any other pins.
    Dec 2003
    If the each upper and lower ACM and DCM show continuity to each relative terminal with the label assumed reversed, then it confirms that it is in fact backwards.
    Nov 2012
    Look at the bottom row: ACM is #5 from the left, DCM is #5 from the right. If they are connected internally (and I suspect they are), there is no way to tell if the label is backwards or not.
  8. #8
    Dec 2003
    THAT is my point!
    They are isolated from each other. At least every one I have measured.
    Oct 2017
    Thank you mactec, citizenofdreams and AI for the quick responses and ideas.
    I performed both tests with no power applied. Used my multi-meter on the beep setting and then on measurement setting.
    When I put one end on ACM (top row) I only have continuity on the DCM (bottom row). None of the other terminals beeped.
    When I put one end on DCM (top row) I only have continuity on the ACM (bottom row). None of the other terminals beeped.
    (Referencing the upside down labels)
    | RS+ | RS- | VI | AI | ACM | 5V | - | DCM | 24V | FB | FC | FA |
    Resistance between FA FB = 21.22K
    Resistance between FA FC = 2.24K
    Resistance between FC FB = 20.98K
    Resistance between VI RS+ = Open
    Resistance between VI RS- = 0
    Resistance between RS- RS+ = Open
    These readings suggest the label is backwards.
    FWIW - If I were placing labels (written in Chinese) on VFD terminals, I could make this mistake.
    Thank you !
  10. #10
    Jan 2005
    Thank you !
    That is so true, most don't realize how different that is to them in English
    You may be able to carefully peal it off and put it on the correct way
    Mactec54
  11. #11
    Oct 2017
    I am going to try to salvage and reapply the label. It looks like everything is working. I can start/stop and adjust speed from UCCNC over the USB to RS-485 adapter.
    When folks use these adapters, do they still use a relay from the BOB to turn the VFD power on? Currently I have to do it by plugging it in. I have the UC400ETH and 2 C10 BOBs. Can I run an output to the VFD from the BOB to do this?
    Thanks everyone for helping make this milestone.
    Doug
  12. #12
    Dec 2003
    If using the pseudo Modbus interface, all control is made via this, There is a plug in for the Mach written for the Huanyang VFD.
    It is not quite standard Modbus.
    If the Bob has a open collector output it can also be controlled direct, see https://www.cnczone.com/forums/spind...equipment.html
    Jan 2005
    Doug
    You don't want to be plugging / unplugging your VFD Drive this is a bad idea, the VFD Drive will not like you doing this
    Yes you can use a relay controlled from your Breakout Board You connect the Rely to FOR and DCM, this works just like a switch, you will need to change a Parameter and the Jumper for Terminal use
    Attached Thumbnails Attached Thumbnails HY VFD Wiring Label - Was it placed upside down ?-dcm-png   HY VFD Wiring Label - Was it placed upside down ?-j1-jumper-png
    Mactec54
  14. #14
    Dec 2003
    Doug
    Did you have any luck with the RS-485 control?
