Hi ho!
My father bought a CNC machine from China, and in the process of rebuilding it from RichAuto DSP to Smoothstepper controller, we also need to change some settings on the inverter.
The inverter:
Type: Folinn (Fuling?) BD 600 series
Model: BD612-5R5-2-DK
Input: 3PH 22v 50/60Hz
Output: 3PH 0-220V 0-1000Hz
Power: 5.5KW 23A
The manual for the inverter is located here:
https://www.dropbox.com/s/zfqqm3lxca...anual.pdf?dl=0
The issue is that when we try to access the menu in accordance to the manual, we only get the ability to change 32 settings, none of which is clearly labeled in the manual. It simply says "F00" for instance for the first object in the menu. Pressing "PRGM/ESC" when F00 is selected allows us to change a value that is 400 by default. I'm guessing this is HZ or something. The same goes for the 31 other settings, there are no submenues as the manual describes.
I would like to change the setting F00.01 so that we can use the built in keypad instead of using wired/remote control which the old controller system uses (which we have no clue how is set up) to stop/start the spindle and adjust the spindle rpm.
Does anyone know what we are doing wrong, and how to access the menu of the inverter?
Thanks in advance
