Your wiring should have the Green wire as Ground /Earth , Green should never be a Power Wire
These Parameters should get you going, note some are adjustable
AskPower Parameter Settings For 50Hz Ac motor
Mactec54
Pn01=2 ( Number of Motor Poles Will Display synchronized speed)
( Pn01=1 Will Display Frequency )
Pn02=50Hz (100Hz if you set your motor to Max Hz )
Pn03=2 ( VFD Button Control Only ) ( 4= External 0-10v )
Pn04=1 ( VFD Button Control Only ) ( 2= External Control )
Pn05=3
Pn08=10 ( This is adjustable Acceleration and Only is a Starting Number )
Pn09=10 ( This is adjustable Deceleration and Only is a Starting Number )
Pn10=50Hz ( Max 100Hz Setting )
Pn11=30Hz ( Minimum Speed adjust to suit your machines needs )
Pn12=50Hz ( Motor Rated Hz )
Pn013=1 ( Be careful with this setting as this can Damage Your Motor )
Pn014=50 ( adjust/ increase to suit for lower RPM Torque, Max setting 100 )
Pn17=30 ( adjust/increase to suit Stopping Max 40 )
Pn19=4 ( External 0-10v control )
Pn32=1 ( Set to 3 to Restore Default Parameters ) ( Set Back to 1 to ReSet Parameters )
