Hey man!
Thanks a lot for your very detailed response, you rock!
Ok, so if I've understood correctly, I should wire the VFD to the breakout board like this, right?
By looking at other forum posts and pics found on the internet, I also got wiring alternatives, like these:
Someone in the Root CNC group also linked me
this post in which you can see there is a quite similar connection to the one you suggested, apart from a strange exchange between the couples (common grounds, I think) of terminals on the vfd, so
FOR with ACM and
VI with DCM but I assume it would be the same, right?
And last but not least, someone else also said this:
I think you may also need to connect one of the "Range" inputs (SPL, SPM, SPH) to DCM. It isn't clear to me that ther FOR/DCM will Stop if it is opened. (And this action may be programmable in the inverter setup.) Also not clear to me is whether the PWM will be properly interpreted by the inverter.
Based on your experience, which wiring is correct and also the best to gain the full control of my VFD-controlled spindle via Mach3, using my board?
Last question, I promise: you wrote me a list of parameters to set into my spindle: but I'm not totally understanding which is correct to set and which is not. Are the one you wrote first the correct one or should I choose the right case in the brackets? Saying this 'cause I'm not totally sure I will choose correctly, so sorry for this but I would like to understood perfectly before damaging something!
Thanks a lot for your support
