Still a bit unclear on proper spindle grounding
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Still a bit unclear on proper spindle grounding
    Member QuinnSjoblom's Avatar
    Nov 2017
    bigfork
    Default Still a bit unclear on proper spindle grounding
    So I have the common 2.2kw spindle and vfd. Plug has 4 wires, I figured out that pins 1 through 3 are for phases but pin 4 is connected to nothing inside the spindle, no ground. How do I do this properly? I have 4 conductor cable with braided sheathing. Should I just run the ground wire to a bolt on my spindle mount instead of the 4th pin? Or open up the top and ground it internally? Also what about the braided sheathing? Ground it at the spindle? Or at the vfd? Or both? Lots of conflicting info out there. What is proper?
    Member coherent's Avatar
    Apr 2003
    Arizona, USA
    Default Re: Still a bit unclear on proper spindle grounding
    My understanding is, ground the ground wire (the green wire) from VFD ground to the spindle housing or mount if there is not a dedicated ground connection at the spindle. The shielded cable braid should be grounded at only one end... grounded at the VFD, but don't attach it to anything at the spindle end.
    Nov 2017
    bigfork
    Quote Originally Posted by coherent View Post
    Yep, that's pretty much what I assumed. Thanks
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by QuinnSjoblom View Post
    Remove the top of the spindle is the correct way and connect the # 4 pin inside
    The Shield for a VFD to Spindle needs to be Grounded at each end, this is done by folding the shield back and clamping it in the plug cable restraint
    There is another way that I have been using, and that is to not use the plug at all and wire direct, using a Cable restraint Gland designed to be used for Shielded Cable, this is much better than using the Plug that come with these spindles
    Attached Thumbnails Attached Thumbnails Still a bit unclear on proper spindle grounding-ground-wire-2-jpg   Still a bit unclear on proper spindle grounding-metal-gland-wire-restraint-png   Still a bit unclear on proper spindle grounding-shield-termanation-4-png
    Mactec54
    Jan 2005
    The shield must be Grounded at both ends, at the VFD drive and at the Spindle
    Mactec54
    Nov 2017
    bigfork
    I've heard from multiple sources that shielding is not supposed to be grounded at both ends for it to shield properly. Is this not true?
  7. #7
    Mar 2017
    X2 on being confused.
    There is conflicting info out there. I saw one YouTube video with a vendor wiring a Chinese VFD to Chinese spindle and not connecting the ground pin at all. I have also seen diagrams showing a ground wire going from the spindle to seperate box labeled "ground" that didn't seem to be on the VFD or the spindle. I have also seen diagrams showing a wire going from VFD ground to spindle ground.
    This really shouldn't be confusing. There are 3 wires going from power outlet to VFD and either 3 or 4 going from VFD to spindle. It shouldn't be that hard to write clear instructions aimed at the hobby-level user (which is what Chinese VFDs are sold for), or label all the pins with useful titles instead of meaningless letters.
  8. #8
    Jan 2005
    Yes that is not true, they are misinformed, in a lot of counties it is a code requirement when using a VFD Drive
    Mactec54
  9. #9
    Dec 2003
    This occurred originally with the implementation of relatively low voltage control systems, CNC etc used in conjunction with high voltage machine/spindle control etc.
    The concern was that it could encourage ground loops to occur, inducing noise into low voltage cables, since then it has been a recommended practice to implement something called equi-potential bonding, this is ensuring that each part of the machine and motor frames have a earth conductor, preferably sourced from a Star point ground.
    This helps ensure that no difference in potential occurs in any part of the machine and allows earthing both ends of shielded cables.
    Jan 2005
    Quote Originally Posted by Goemon View Post
    The Chinese are not going to write anything for you, they are only interested in selling what ever they can, good or bad, I'm not sure why there is no electrical code enforcement of the imports from China
    This is information in most cases, is a nightmare for Hobby users, that should not be doing high voltage wiring, before anyone writes this kind of information they should look up there Electrical Codes, or consult and industrial Electrician, 3ph power is not something you just mess with, unless you know for sure what you are doing, videos in most cases are very misleading, and unless they are done by a VFD Drive manufacture, (which there are some ) most all others have some miss information in them
    The only country in the world that uses 3ph motor without a Ground is China, this is the reason that you see all these low quality Spindles and AC motors coming from China with no Grounding Terminal, the 3 Pin Spindle Plugs and the none connected 4th Pin on the 4 Pin Plug Spindles all have to be corrected before they can be used
    Correct Shield termination and Ground is a must even at Hobby level
    Cable Shields terminated at one end provide only electrostatic protection against low-frequency, capacitive coupled interference and emission
    Mactec54
  11. #11
    Nov 2017
    bigfork
    So if grounding both ends of the sheild, doesn't the 4th conductor in the cable as ground become redundant? Do you still want both the sheild and the wire grounded at both ends?
  12. #12
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    The shield is not a ground. It's the shields job to contain noise. The ground is there so you don't get killed.
    UCCNC 2017 Screenset
  13. #13
    Mar 2017
    Post Re: Still a bit unclear on proper spindle grounding
    Nobody wants to be wiring up high voltage spindles (or anything else) but until somebody comes up with a standard spindle to VFD cable (which they should), they have to if they want to build a CNC machine. It's not realistic to expect that all hobby level users and small shops will hire an industrial electrician to connect their spindle wires. I seriously doubt an industrial electrician would even accept the job. It's hard enough to get a residential electrician to do some wiring for a reasonable price.
    I have wired up a bunch of high voltage projects and some that are considerably more dangerous than CNC spindles (like CRT arcade monitors which hold lethal current even when unplugged). I am perfectly capable of following instructions and taking the suggested safety precautions. IMO, where it gets dangerous is when the instructions are wrong or misleading.
    This risk is worse for CNC wiring than anything else I have attempted because there are too many people offering conflicting bits of advice. We have no way of knowing who really understands this stuff vs people who are regurgitating innacurate info. Electricity is one area where I like to be 100% before flipping the switch.
    It doesn't need to be this hard. With clear, simple and accurate instructions, connecting wires to screw terminals is not a difficult job
  14. #14
    Jan 2005
    Just last week I was asked to setup / make some cables for VFD drives to Spindles, this is not very difficult to do, if you are uncomfortable in making a simple cable like this then do you think you should be building a machine like this
    You will see who's information is correct, by looking it up in the electrical code regulations, they are not easy to understand, still the best place to look to see if you are doing something you should not be doing also, any good professional Video that has been done by the company that manufactures the product, is another good place to look, most you should not look at, as they have many problems that are incorrect examples of wiring Etc, even the pro's don't normally do a 400Hz spindle, just think that a few years ago the Hobby user could not get or use anything other then a hand router
    Mactec54
  15. #15
    Dec 2003
    Back in the 80's when I started doing CNC retrofits, Mitsubishi, Fanuc etc, these systems all had integrated type spindles, except they were called spindle drives then, not VFD's.
    At that time though, VFD's started arriving on the scene for general 3ph induction motor control.There were no defined instructions or any special cable recommended for the VFD to motor.
    The cable manufacturers started getting in on the action and the first that I can remember to bring out a specialty cable was Belden.
    This is some of their products and instructions.
    I made my own.
    Attached Thumbnails Attached Thumbnails Still a bit unclear on proper spindle grounding-vfdcable-jpg   Still a bit unclear on proper spindle grounding-vfd_cable_termination_guide-pdf
    Member ClintonCarawayCNC's Avatar
    Oct 2019
    Why would you not ground the wire in the braided shielding
    To the ground on the spindle side??? Please answer carefully because I really don't want to have to re-solder my aviation connector.
  17. #17
    Dec 2013
    Quote Originally Posted by ClintonCarawayCNC View Post
    Normally you would only ground the shield braid at one end to prevent ground loops. Most common connection is at the VFD end. You would connect the motor ground wire at both ends.
    Jim Dawson
    Sandy, Oregon, USA
  18. #18
    Jan 2005
    You should not be soldering the shield to anything
    A Ground Connection is not somewhere you connect a Shield too, So, Ground wires to there Ground Terminals only
    For the spindle Plug Shield, because these plugs are not EMI Shield Grounding plugs, you don't have any choice other than to fold the shield up and clamp it with the Cable restraint clamp no ideal but the only choice you have
    The Plug is Grounded through the Body of the Plug and this in turn will Ground the Shield
    Mactec54
  19. #19
    Jan 2005
    Quote Originally Posted by Jim Dawson View Post
    You should not answer questions like this if you don't know the correct way to install a shielded Cable for a VFD Drive
    All Shields must be Terminated at both ends, every VFD Drive Manufacture will tell you this, in some countries it is a Code Requirement
    You can not create a Ground Loop if everything if correctly Bonded
    Do you know what a Ground Loop is ???
    Mactec54
  20. #20
    Dec 2003
    Jeez Jim, what were you thinking!:
