Re: VFD Setting Help not much torque at low speeds.
Originally Posted by Cartierusm
240VAC, wired it according to the wiring name plate for low voltage, which is 230VAC.
Okay....if you connected the motor in Delta/low voltage then that's good. Many people make the mistake in this case and connect in star, this will cause reduced torque.
