Newbie need help on combo ac power supply speed controller
Results 1 to 2 of 2
Thread: need help on combo ac power supply speed controller
    Oct 2011
    Default need help on combo ac power supply speed controller
    Have a Chinese HQ-SXPWM combo speed/ power supply, brand new. When plugged into 110 motor runs but on off switch does not function and speed control does not adjust the rpms? It is wired correctly. Could use your help Is this the right area in the forum to ask? Thanks, Knifemaker
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: need help on combo ac power supply speed controller
    If it is indeed wired correctly and it does not work, then it's dead. You can either send it back, or open it up and check the components, starting with the output transistors.
