VFD interface to other equipment. - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 99
Thread: VFD interface to other equipment.
  1. #41
    Registered racetech's Avatar
    Jan 2018
    Yes that will give you a Relay plus the 0-10v PWM
    Any idea how to hook up to what I have ? Well I tried to hook the board up and try just the spindle controller part and the board has a 25db male end my cable is a male on both ends .. scratching my head !
    Attached Thumbnails Attached Thumbnails VFD interface to other equipment.-b17c9668-71e9-4bbc-bd95-f641d34888f8-jpg   VFD interface to other equipment.-f5fc10ba-941c-440e-8a12-29402adb1f66-jpg
  2. #42
    Registered diyhands's Avatar
    May 2017
    Quote Originally Posted by racetech View Post
    You need these sir...
    - - - Updated - - -
    https://www.amazon.com/gp/aw/d/B014X1SZIA/ref=mp_s_a_1_3?ie=UTF8&qid=1518617601&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=Db25+coup ler&dpPl=1&dpID=41F1a-F-vTL&ref=plSrch
  3. #43
    Jan 2018
    Default Re: VFD interface to other equipment.
    I can’t get that link to work . Maybe it’s my phone . I will try it on computer when I get off work .
  4. #44
    Jan 2005
    This may work for you they are called a gender changer you can get them in any combination you need
    https://www.ebay.com/sch/i.html?_nkw...male+to+female
    Mactec54
  5. #45
    Jan 2018
    Ordered one and they are in Chicago not far from me hope to get by weekend if I do I will hook it up and see if I got rpm control and let you know how it goes .. thanks again ..
  6. #46
    Jan 2018
    Hi Mac I hooked up the eBay board like the wire diagram shows on a YouTube video the motor turns on and off in Mach but still no speed control like the geko the only thing that is better when I turn off the board the spindle stays off unlike the geko it starts . I must be missing something in the vfd setting.
  7. #47
    Jan 2018
    Pics of wiring
    Attached Thumbnails Attached Thumbnails VFD interface to other equipment.-7d22f1d2-4bff-4721-8842-9e3606a2629a-jpg   VFD interface to other equipment.-d073a35f-f057-4cde-99ac-e95ef9bf5ea0-jpg
  8. #48
    Jan 2018
    Pics of wiring
    Manual vfd pd001 set to 01
    Pd002 set to 0
    That’s the only setting that will turn spindle on and off on Mach 3 if I change them I only hear the relay click no spindle
    Attached Thumbnails Attached Thumbnails VFD interface to other equipment.-5da74a38-4699-4fe7-9bf5-6d05901254b6-jpg
  9. #49
    Jan 2005
    Pd002 set to 0
    Have you added the 12v power supply, between the relay out and the 0-10 v out, connect this correct as well watch the where you put the +/- connections, if you have you can then check for the 0-10v out from the board once you get that working then you will should have speed control
    Also do you have the jumper set for terminal control
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control ) ( J1 Also Needs to be set for Terminal Control )
    Mactec54
  10. #50
    Dec 2003
    This thread appears to have strayed off track from its original intention,
    The main idea behind this thread was to demonstrate how easy it is to interface the Digital output of the G540 to any VFD or controller PLC that uses a source input in order to use the G540 sink output for FWD command signal.
    This method is intended to eliminate or exclude the alternative to an intermediate relay.
    Which incidentally the SuperPID Triac Spindle controller manual also shows as the recommended way.
    The device interfacing the G540 to has to be able to either use the typical opto input that has a source voltage or one that can be configured for source or sink, the Huanyang for example has a set (non-configurable) sourced PLC input.
    Any further posts that are not relevant will be given their own thread.
    Al_The_Man
    Member shisa7807's Avatar
    Dec 2018
    Ottawa
    Pin 12 on geko to DCM on vfd
    Pin 5 on geko to FOR on vfd
    Pin 7 on geko to ACM on vfd
    Pin 8 on geko to VI on vfd
    Pin 9 on geko to 10v on vfd
    This works in Mach to turn on and off the motor with Pd001 -1 and Pd002-0 if I change those numbers in the vfd settings the Mach will not turn on motor . Now with the above settings it turns on and off no motor speed control. The problem is if I power off the geko after I stop the motor in Mach the motor powers back on if I take the dcm off pin 12 on geko the motor stops and it will not power on that way unless I hook dcm back to pin 12 on geko.. I want to thank all that is chimming in as this is all new to me I’m a great hands on fabricator and got this mill to make things nicer and get my son involved on the cnc also .. thanks again .
    Hi Racetech,
    Did you figure out a solution to this problem?
    I'm experiencing the same problem as you are. All of it, including spindle powering back up when the G540 is powered off. With the way that it's wired (as mentioned above) and Pd002 = 1, I can turn on/off the spindle using Mach3 but not adjust the speed.
    Any fix to this issue would be much appreciated.
  12. #52
    May 2010
    This was a most helpful thread for getting my G540 and LinuxCNC running the Huanyang VFD and Chinese spindle on my small CNC. I started with Al_The_Man's post #1 and quickly got forward working and then quickly added reverse just because why not. I used a combination of the G540 manual and some other forum thread to wire up speed control.
    Here's my wiring breakout
    G540 Pin => VFD
    5 => FOR (forward)
    6 => REV (reverse)
    7 => ACM (speed control)
    8 => VI (speed control)
    9 => 10V (speed control)
    12 => DCM (forward/reverse)
    I changed two VFD settings to reflect computer control: PD001 from 0 to 1, PD002 from 0 to 1.
    As I was running through wiring, in three phases (forward, reverse, speed), I ran stepconf (sp?) in LinuxCNC to create a dummy configuration just for testing, then copied the applicable settings from the dummy .hal file to my regular .hal file.
    All told, I spent maybe 2 hours in wiring, quadruple checking wiring, checking pinouts between G540 manual and configuration files, research, adjusting configuration files, etc. If I had to do it again today, it would probably take about 15 minutes at a slow pace and carefully validating wiring correctness.
    This is going to be so convenient, especially as I want to mount my control box in a location that won't be convenient to get to the VFD frequently; instead, I only have to turn the box on and off via easily accessible buttons on the outside.
    Thanks Al_The_Man,
    Roy
    ________________________
    My [URL="http://www.cnczone.com/forums/cnc_wood_router_project_log/130932-roys_first_machine.html"]First Machine Build Log[/URL]
  13. #53
    Sep 2005
    Quote Originally Posted by diyhands View Post
    Sorry Mac,
    Yea I tried the Pin5 to enable spindle DIR ...... I couldn't get the signal on the pin with Mach3 settings..
    DIY
    I wish this was more legible. I can't make out hardly any of it.
  14. #54
    Member brianhatley's Avatar
    Mar 2020
    Quote Originally Posted by shisa7807 View Post
    Hi Racetech,
    i am also having this issue. spindle turns on when i flip the g540 off. in addition my spindle only stays on for a second then turns off when i try to turn it on in mach3
    i am not using a relay, just wiring it up using the diagram above
  15. #55
    Jan 2005
    Quote Originally Posted by brianhatley View Post
    What VFD Drive do you have not all of the VFD Drives can be wired the same
    Mactec54
  16. #56
    Mar 2020
    Don’t mind the toggle switch. Just temporary way to keep the thing from being on while my G540 was off.
    Hy02d223b
    Attached Thumbnails Attached Thumbnails VFD interface to other equipment.-12ab68b9-d95d-44a1-8f89-c32fabeaf996-jpg   VFD interface to other equipment.-5d7cece7-20b6-4823-9a45-6eb2d42427e5-jpg
  17. #57
    Mar 2020
    I’ve been reading such different approaches to the same components I have, I can’t get any of them to work. My next thing is to try an order an rs485
  18. #58
    Dec 2003
    See http://royaumedeole.fr/informatique/...-huanyang-vfd/
    Mar 2020
    So the rs485 is my only option then? I’ll have t
    Order one if so. I was hoping to get it to work with what I have now
  20. #60
    Jan 2005
    If you don't have a relay for the On / Off then it is not going to work with this VFD Drive from the G540 output you have to switch a Relay On / Off from the control and the output of the Relay is then connected to the FWD and ACM Terminals there is no voltage involved with this so if you have used any voltage to these connections you may have some damage
    Or use the Modbus which can be a challenge also for some to setup
    Mactec54
