- Need suggestion for high frequency VFD (2000Hz-5000hz)
I have some ATC spindles which use ceramic bearing & air bearing (Jager, Precise,...). The problem is their working frequency is around 2000Hz to 5000Hz. I cannot find any affordable VFD ($100-$500) for these spindles. Can you recommend which VFD should I buy?
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
