Well i got the 220 line ran this morning and the vfd is now set up (input and output power only). I did turn the spindle on and watched it ramp up to 100hz then turned it off. I did this every 100 hz until it hit its max of 400 hz. It is a water cooled spindle and that is not connected yet so i can not play with it to much. However, that spindle is so quite it is unbelievable - im used to routers and there is no comparison. I have not changed any parameters from the default yet and surely havent moved into seeing if i can control the spindle from my UCCNC. The parameters listed in the sheets below befuddle me.
