Huanyang Chinese VFD settings and manual here! - Page 41
Page 41 of 41 FirstFirst ... 3138394041
Results 801 to 808 of 808
Thread: Huanyang Chinese VFD settings and manual here!
  1. #801
    Member mactec54's Avatar
    Jan 2005
    Default Re: Huanyang Chinese VFD settings and manual here!
    Quote Originally Posted by HeavyMental View Post
    I used the settings that you posted for me earlier in this thread. (Thanks again.)
    Someone else sent a link to Automation Technologies where they listed basically the same settings you listed with a few differences.
    But I have checked and double checked that PD003, PD004, PD005 and PD072 are set to 400 and that PD144 is set to 3000.
    In fact, even though the VFD is new, I did a factory reset and entered everything a second time... just to make sure there were no errant settings somehow.
    Listed belown is what I worked from. The italicized are some settings I was curious about.
    I have tried changing PD006 to 3 because I am to understand that 2.5 is for 50Hz.
    Looking at the manual I was wondering about PD009 and PD010. It seems as if they need to be lowered for my 110V VFD since those settings are for 220.
    All that being said, I can't imagine how these would affect the max frequency.
    From CNCZONE Forum From Automation Technologies
    PD001=0 (1 For Remote Control) PD001=0 (1 For Remote Control)
    PD002=0 (1 For 0-10v Terminal Control or Remote Trim Pot Control) PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    (J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection) ( J1 Also Needs to be set for Terminal Control)
    PD003=400 PD003=400
    PD004=400 PD004=400
    PD005=400 PD005=400
    PD006=5
    PD007=20 PD007=20
    PD008=110 (Motor Rated Voltage) PD008=110 (Motor Rated Voltage, If you have 220v spindle then set to 220v )
    PD009=15 PD009=15
    PD010=15 PD010=8
    PD011=120 (120 Minimum Setting For 110v Spindles) PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD013= 08 (is for Factory reset Only use this to set VFD to Factory Default Settings) PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=8 (Adjust to suit) PD014 Acceleration = 12 ( Adjust to suit)
    PD015 Deceleration=8 (Adjust to suit) PD015 Deceleration=12 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD041=8 (Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=100 (Stall Prevention)
    PD141=110 (Motor Rated Voltage) PD141=110 ( Motor Rated Voltage ) (220 for VFD Rated for 220v )
    PD142=9 (Motor Max Amps 2.2Kw Spindle 9 amp) PD142=9 (Motor Max Amps 2.2Kw Spindle 9 amp)
    PD143=2 (Motor Number of Poles) PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) 3,000= (24,000) PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD070=0 (This may need to be set to 1 if Control Voltage is 0-5v) PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD072=400 PD72=400
    PD073=120 (120 Minimum Setting 110v Spindles) PD73=120 ( 100 Minimum Setting )
    PD174=11 (To Be Set to the VFD Drives Max Rated Output Amps)
    As you can see Automation Technologies is just a Copy of what I post, the few differences are from other variation's I have posted
    Did you Change PD070=1 for Pot control and move the J1 Jumper
    There are other Parameters that can be changed but if you have it running then you are not far away
    Mactec54
  2. #802
    Jan 2005
    Here are some changes you can make; you may be able to up the amps PD142 to 12 but see how it run first with these changes
    PD141=120
    PD006=260
    PD008=120
    PD009=78
    Mactec54
  3. #803
    Feb 2005
    United Kingdom
    Default Re: Clone HY02D223B Huanyang Chinese VFD settings
    Clone HY02D223B
    Unbeknown to me, until now that is,
    I have been landed with a Chinese 'clone' version of the HY02D223B VFD
    It is evidently clear that the parameter list differs from that of original version.
    Although the clone does not have Modbus capability it still performs well.
    I have some initial Parameters i.e-
    * Pn 01=24000
    * Pn 02=400
    * Pn 02=2
    * Pn 04=1
    * Pn 12=400
    Notice we have PN instead of PD on the parameter listing.
    And as far as I'm aware that's the only obvious difference between the Clone and the Genuine VFD.
    Does anyone have a full Parameter list for the clone please.
    I'd be very grateful.
    Many thanks.
  4. #804
    Feb 2005
    United Kingdom
    Hi Terry
    Do you happen to have the Full parameter list for the Clone HY02D223B Inverter.
    * Pn 01=24000
    * Pn 02=400
    * Pn 02=2
    * Pn 04=1
    * Pn 12=400
    Many thanks.
  5. #805
    Member PatenteAgosse's Avatar
    May 2023
    hello, Any Idea where to go with that. 110V 600W. That is the only infos I have (see attached). I asked for more but still waiting. The motor name plate is limited also to : 110Vac, 13000rpm...
    this is the settings I have now but not sure of them. I have 12000rpm on the tachco with those. I did not tried to get 13000 and happy with 12k. What do you think?
    PD002=0
    PD003=400
    PD004=400
    PD005=140
    PD007=10
    PD008=110
    PD011=120 (Minimum Setting 120)
    PD009=10
    PD010=5
    PD014 Accel=10
    PD015 Deccl=10
    PD142=5 ( I went 693w/120v=5.76 and rounded it at 5 as a safety margin to start.)
    PD143=4 ( Motor Number of Poles)
    PD144=1500 (3,000=24,000) /2
    Attached Thumbnails Attached Thumbnails Huanyang Chinese VFD settings and manual here!-motor02-jpg
  6. #806
    Sep 2006
    Quote Originally Posted by Georgie View Post
    Hi Terry
    * Pn 01=24000
    * Pn 02=400
    * Pn 02=2
    * Pn 04=1
    * Pn 12=400
    Many thanks.
    I think this is the manual you were looking for. I found it on the Australian Vevor website. https://d2v0huudrf11kh.cloudfront.ne...4738270427.pdf I had exactly the same problem as you. I think it is a different VFD to the often linked to Huanjang VFD. This one has the PN prefix on its parameters. I checked the parameter PN33 which is set to 32u29 and from that decided it was the same VFD (HY023D223B)
    Attached Files Attached Files
  7. #807
    Member Gamby's Avatar
    Jun 2019
    I have been having trouble setting up my drive. I am using it with 110v CNC Router spindle with a Centroid Acorn control board. I entered the parameters from Automation Technologies but the drive did not hold the settings when powered off. Now when I go back in I am unable to set PD003 to anything more than 50.000.
    Can anyone offer any insight as to what I might be doing wrong?
  8. #808
    Woodcarver75's Avatar
    Oct 2023
    I purchased a kit from Bulkman3D. It was the ultimate bee version 220v 2.2k air cooled spindle.I am another person who can not figure out how to get the HY02D223B to operate. I have watched several videos and read many forums. Wouldn't you know, no two posts share the same settings..... I have attached my settings. I am not sure if something is wrong with them or if i am missing some.
    I am using the CNC3D commander and the CNC3D NightHawk as the commander. it sends the 10vdc signal to the VFD.
    I can not get my spindle to rotate using the commander. I know i need the jumper set to V1. But if I remove the V1/VR jumper so its on VR and change pd1&2 the spindle will move. In fact it rev's up within a few seconds and i stop it before it flattens out. the display on the VFD does not show me a value running like this. So i hit the stop button so not to blow the spindle. I am at a loss here. I purchased this kit back in May and still have not used it...
  9. #809
    Member Marcel63's Avatar
    May 2019
    Hi All
    Well I have an issue with my Huanyang 1.5 kw 110 volt and 800 k spindle. the rpm is way off by half.
    I have a masso g3 control and if I type in a s1000 my vfd displays roughly 2000 if i put in 12000 it will display 24000 but it will not go higher not sure if the spindle is running 24000 or 12000 but it has a max speed of 24000. I have setup I think all the pds like they say.
    so is there a pd i have to set for the rpm and how do you find what to set it to I have pd144 =3000
    any help will be helpful
    Marcel63
