Calibrating my machine
Results 1 to 11 of 11
Thread: Calibrating my machine
    Aug 2014
    Default Calibrating my machine
    My first machine was belt driven and mach3 would calibrate. I changed to ball screws and i have been unable to calibrate. Any suggestions?
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Calibrating my machine
    By "calibration" do you mean finding the correct steps-per-unit values?
    Aug 2014
    Yes
    Nov 2012
    Those are pretty easy to calculate without using Mach3's wizard. Post some information about your machine:
    - ball screw thread pitch
    - ball screw number of starts
    - stepper motor degrees per step
    - stepper driver number of microsteps per step
    - any gearing between the stepper motor and the ball screw.
    Aug 2014
    SFU1605 RM1605 1605 Ball Screw
    Pitch is 5
    Start is 5
    Nema 23 57mm Stepper Motor High Torque
    200 steps
    Nov 2012
    You did not say what your microstepping is, but let's assume it's 8.
    Then your steps-per-millimeter would be:
    200*8/5=320.
    If you are using inches, multiply 320 by 25.4.
    P. S.
    According to the Internet, SFU1605 is single-start, not 5-start. So it has 5mm thread pitch and 5mm lead.
  7. #7
    Aug 2014
    16
  8. #8
    Nov 2012
    Then 200*16/5=640 steps per mm.
  9. #9
    Aug 2014
    Thank you for your help. When i am twicking movement when movement is more than requested do i add or substrat ?
  10. #10
    Aug 2014
    Thank you.
  11. #11
    Nov 2012
    If your ball screw is accurate (and it probably is), then the calibration should be spot on. But if you do need to tweak it, then BIGGER steps-per-unit means BIGGER movement.
    edited. sorry, got it wrong the first time.
