You are changing linear to rotary motion, not so easy.
now you need All 4 axis X Y Z A output
(been there with 7-axis robots)
Your CAM software supplier should be the one to question.
Hi all,
I an new to CNC in general but I have been running a mill and lathe for a while. I just got a 4 axis router (cheap and Chinese) and I want to put my simple logo on a tube-shaped part. I have got is working be swapping the wires for the x and a axes, but I really want to get it working properly. I created my artwork using Qcad and Inkscape, but it only generates gcode for XYZ. I think it should not be too hard to post process the X axis into the A axis, but all of my attempts so far have not been successful. I am a pretty fair Python programmer and I have written a couple of post-processing scripts to parameterize the output of Inkscape (my way). Anyone have any ideas on how to get this working? I don't mind posting what I have if there is any interest.
All the best,
Chuck Tilbury
Pflugerville, Texas
- Open Source : 4 axis and 5 axis print with a 3 axis milling in order to have a 5 axis
- In the process of acquiring 4-axis CNC router - advise appreciated
- Need Help!- Edgecam 5 axis post processors for haas umc 750 (with B+C axis)
- 4-axis rotary CNC engraving machine for process cylinder material in vertical
- new product -5 Axis CNC process Center MT-CW 2660
Been doing this too long
