- Yuasa Microstar N1 CNC Lathe
Hi all, I just purchased a Yuasa cnc lathe with fanuc controls. The machine runs "I haven't run it yet", but there is a issue with the "x-axis reference zero return". I am no expert when it comes to problem solving these types of things, the guy I bought it from says that it's a easy fix/repair. Could there be a problem with the limit switch? Any help would be greatly appreciated and anyone who has any experience with these machines I would like to hear their comments on them as well, THANK YOU!!!
Re: Yuasa Microstar N1 CNC Lathe
Notchtopper,
Hi, I have aquired one of these lathes. I also am in need of some help.
I don't have any technical documentation on mine. I was hoping to find some sources.
I have the gang style x axis. The controls look pretty much obsolete. I was planning on retrofitting this to run from Mach3.
Not sure what kind of servos or servo controls are on this, looks like a DC spindle motor, can't get any details on the spindle controller.
Do you have any details on yours?
Arnie azminear@gmail.com
- You may not post replies
- You may not edit your posts
Forum Rules
