Hardinge CHNC conversion - Page 25
Page 25 of 25 FirstFirst ... 1522232425
Results 289 to 297 of 297
Thread: Hardinge CHNC conversion
  1. #289
    Feb 2006
    Quote Originally Posted by agwelder View Post
    Hi Vince,
    Looks like you've done a really nice job on your Hardinge. We retrofitted an HNC last year had trouble using the Hall effect limit switches with our setup. Our frustration was to the point we changed to mechanical switches and moved on. We are building another HNC with PMDX BOBs and we would like to use the existing limit switches. If it's not to much trouble, could you give us a rundown of how those are wired in?
    Thanks in advance, Adam
    The sensors are really easy to hook up to the PMDX board. The black wire from the sensor goes to the ground of the PMDX, the red wire connects to the +5 auxout, and the white (signal wire) terminates on the input you want to use, pin 15, 13 etc. No need for pull up resistors. They can also be paralleled without any problem. All of my Hall switches are paralleled on each axis.
    Vince
  2. #290
    Sep 2004
    I've just come across this thread, and have read through all 25 pages. I admire your deication, and I especially appreciate you taking the time to post so regularly. Nice work!!!!
  3. #291
    Gold Member BobWarfield's Avatar
    May 2005
    Yeah, this was a cool thread.
    Vince, do you still have the lathe and is it working well for you?
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  4. #292
    Feb 2006
    Quote Originally Posted by BobWarfield View Post
    Best,
    BW
    Thanks for the kind words. I still have a lot I want to do, but at least I can use the lathe now.
    Vince
  5. #293
    Oct 2005
    us
    N4NV-
    I tried to PM you, but it bounced. said something about storage space full....
    Anyway, mabie you will see this-
    I sent you a PM on youtube a few hours ago. Then I found this thread and reckognised the blue paint...
    I would love it if you could give me your email addy so I can pick your brain.
    In particular, I am very interested in-
    Cubloc PN.
    Hall effect sensor PN's and source
    Resistor wattage and values (for between the Hall effect sensors)
    CAD drawing that you used for the turret encoder base plate.
    Copies of the functional Brains/ladders/scripts
    I would love to duplicate your turret encoder and how you make it work with mach and the cubloc.
    I am already running Mach3 and a Smooth Stepper with a C11 (IIRC) BOB.
    I would be happy to pay for your time, trade something, whatever. I love my CHNC, but not having the tool turret functional is driving me nuts.
    Hope to hear back from you...
    Best,
    Nate.
    natefoerg@gmail.com
    Nate.
    Ann Arbor Meechigan
  6. #294
    Aug 2010
    Red face Wow!
    Wow, I must say vince, I just spent the last 5 hours reading through this entire thread. You sir are a gentleman!
    There were so many questions that I had when I first bought my 2 CHNC-2 lathes on thursday, i pick them up tuesday! And because of your detailed intructions and explanations, my conversions will go fairly quick (im thinking 2-3 weeks). I will be working on them 12 hours a day 5 days a week. But I don't think I will completely strip mine as you did, mine were takin out of a job shop, one has a fanuc, and the other doesnt have the controller. They are both in pretty good shape, one is complete and the drive went out, the other is kinda in pieces . But the complete one has a parts shute, which will be awesome to integrate.
    After reading your thread, I have decided to just mount a digital microstepping stepper on the turret instead of the air motor. It seems to me that you and many others had to much issues with it. I did read read on another persons post that they could not get the stepper motor to work well with the turret because of the degree error. I don't think he was microstepping the motor, he had mentioned that he was getting 1.5 degree positional error, which is really high if he was microstepping.
    I understand that tool changes won't be fast, but they should work. And they should be very accurate especially when I microstep them.
    I know there is not a lot of room in the carriage for the stepper motor, so I will be modifing the mounts and extrending the shaft with the worm gear to get the desired movement and clearance.
    For the x and z, I will have keling servos on them, I absolutely love the job u did on modifying the existing resolvers on the ball screw to give great feedback. I have 1000 ppr encoders that I will be adding on.
    I will add to your thread by showing my conversion with pics and videos as well!
    Thank you so much VINCE!!!!
    Mike
  7. #295
    Apr 2008
    Any
    Hi, I have an old hardinge CHNC4. I am having problem with collet closer. there was alot of air leakage so I replaced air with Hydrolic system. Now I have problem that the oil leaks so i am going to replace to bearing with rubber seal bearing.
    1.Please can you tell me what is the part number for the rubber seals ?
    2.does that package also contains the rubber seal for turret assembly?
    3.Do you think it is good idea to replace air with hydrolic?
    thanks
  8. #296
    Feb 2006
    Default Still making parts, good tooling
    I found getting larger tooling and machining it down to 3/8" lets me get much better tooling than what is available in 3/8" tooling. Here are a couple videos of making parts with the new tooling:
    Vince
  9. #297
    Feb 2006
    Default Re: Still making parts, good tooling
    I didn't know, but all this time I could do threading. All I needed was the correct G-code.
    Vince
