New Here New Member From Cape Town
Results 1 to 6 of 6
Thread: New Member From Cape Town
    Apr 2018
    South Africa
    Default New Member From Cape Town
    Hi All
    I am based in Cape Town and has just started building my first CNC.
    I am building a Root 3 CNC but with my guide rails at 40x40mm.
    I will start a build progress thread as soon as I start receiving my first parts.
    Looking forward to contributing and learning from the other members here.
    Cheers!
    Oct 2013
    Default Re: New Member From Cape Town
    Welcome Skillet. I moved to Somerset West from Port Elizabeth a year ago. I have been working on a Tormach PCNC770 for a year and during that time I also converted my BF20L milling machine to a CNC machine. I run it with Mach3 and is also still learning the ropes.
    Regards
    Ockert
    Apr 2018
    South Africa
    Quote Originally Posted by ockert View Post
    Regards
    Ockert
    Hi Ockert
    Great to hear from someone local! I have to admit that I am so new to this that I had to go google the machines you mentioned above.
    These are some serious machinces and so far out of me DIY build’s league!
    I am waiting for most of my items to still arrive from overseas so my project has not gotten Of it’s feet yet. I need to wait to get my gantry plates cut in any way. I did not have much luck with this so far. I ended up thinking of asking a family member to lasercut these from 6mm MDF and then just glue them up to make 18mm thick plates. I can then mill proper plates when the machine starts running. I also got some designing practice using Fusion 360 to create my own dxf’s for these.
    Are you using your machines as a hobby or to generate income? These are obviously metal capable machines. I would be very impressed if I manage to mill some aluminum with my build, even if I need to mill shallow and slow.
    Oh! And welcome to the Western Cape!!!
    Keep in touch!
    Jacques
    Jun 2017
    Hi Jacques, welcome Looking forward to see your build. I moved from Rustenburg to Adelaide few years ago...
    Apr 2018
    South Africa
    Quote Originally Posted by ericks View Post
    Hi Erick
    Thank you!!
    Are you still into CNC down there?
    Dec 2017
    South Africa
    Hi Skillet
    Any progress on your machine.I am where you were a year ago.The dreadful design phase.Any info on local suppliers for good quality structural aluminium profiles.I am looking to build a 1.2 x 1.8 meter CNC router.
    All the best
