Solidcam G code ERROR line 3708
Results 1 to 11 of 11
Thread: Solidcam G code ERROR line 3708
    Member persecan's Avatar
    Jan 2020
    Default Solidcam G code ERROR line 3708
    Member Danpil's Avatar
    Nov 2017
    Default Re: Solidcam G code ERROR line 3708
    You need to see line 3708.
    Jan 2020
    you can give me more details ?
    Mar 2016
    Poland
    In sufficient GPP file is a problem with this line. Maybe just needs to be disabled if the G code looks fine though the error occures.
    Jan 2020
    g code is not generated
    Can I be more specific on how to fix this problem?
    Mar 2016
    Poland
    Gcode is not generated if u press cancel. If u press ok when the error occures it will be generated anyway. With or without wrong lines.
    Anywhay can U show what line 3708 in MT_Nakamura_NTRX300L_Fanuc31i_XZYCB_BS.gpp looks like?
  7. #7
    Jan 2020
    line 3708 does not exist in the gpp file
    Attached Thumbnails Attached Thumbnails Solidcam G code ERROR line 3708-screenshot-2022-03-28-190622-png
  8. #8
    Mar 2016
    Poland
    Lines are not numbered. U need to look at status bar in notepad.
  9. #9
    Jan 2020
    I found the line
    see the picture below
    Attached Thumbnails Attached Thumbnails Solidcam G code ERROR line 3708-1111-png
  10. #10
    Mar 2016
    Poland
    Try putting ; in front of this line. Looks like problem with procedure get_tool_dir_in_station. Maybe it isn't defined, or missing variables.
    Quite probably it won't harm g-code, or maybe not in every case.
  11. #11
    Jan 2020
    thx
    I managed to put ";"
    now the error below appears see the pictures
    Attached Thumbnails Attached Thumbnails Solidcam G code ERROR line 3708-2323-png   Solidcam G code ERROR line 3708-2222-png
