Milling part few mm smaller than it's real size
Results 1 to 3 of 3
Thread: Milling part few mm smaller than it's real size
    Jun 2015
    Estonia
    Default Milling part few mm smaller than it's real size
    Hi!
    I'm new to machining and CAM. What I want to to:
    Make part in SolidWorks 1:1 size
    Mill part 2mm smaller than its 1:1 size.
    Spray part with primer, up to 3mm.
    Mill part to it's 1:1 size.
    So.. Using SolidWorks CAD ja CAM what are the right steps to to it.
    Other thing is probing. Make 2 holes for that or one corner and two sides that will on the same size from the beginning?
    Mar 2016
    Poland
    Default Re: Milling part few mm smaller than it's real size
    U can add an allowance in - (less than 0) U can use tool that is larger than U set in SolidCam, or U can Use sketched line as a geometry for smaller part, and probably some more ways to achieve part regardless model dimmensions.
    Of course U also can make smaller part and 1:1 separately in SW.
    That depends on what U do and what is comfortable to U..
    As for probing I just don't understand what U asking about...
    Jan 2018
    United Kingdom
    I'd do first milling in cam as "stock to leave" (autodesk term) as neg -1mm. This will leave 1mm stock on part all round making it 2mm smaller in total.
    Second milling "stock to leave" as 0.
    Technometals's Avatar
    Feb 2022
    Hey
    I work with a doosan puma 2100 lxy lathe
    Is it possible to perform in solidcam Polygon turning?
