Originally Posted by
dazp1976
Are you using HSM?.
I recall in Inventor it was to do with the "maximum stay down distance" value in the last tab (that comes after the finishing passes etc settings).
If you have a lift/retract distance to next cut of say 80 and you set the above value to 90 the tool will stay down.
This is NOT advised if the said move is a RAPID!!. (unless tool will not be going through any stock).
It might not even be the same cam program as yours anyway, but I would say it would be marked as a "stay down" type setting still.
