I recently moved from a desktop to laptop. I thought I had setup SolidCAM properly but having an issue with our rarely used Tormach 15L Slant Pro lathe.
Initially I just copied the Gpptool folder over and the mill works flaw as should. However when I try to post code for the lathe I keep getting Cycles errors.
"gTurn_2x_Tormach-slant-Pro_Skyyfish_Cycles, Line ##: Variable 'iDrillmode' is not defined"
...or replace iDrillmode with any of the following:
iMotionmode
bIgnoreFirstRapid
eClamp
eCLAMP_CLAMP
eCLAMP
eCLAMP_IGNORE
bYaxisExist
I'm hoping it's a simple fix, like some association that I forgot to make. I read the '...Cycles.gpp' file and saw those terms listed, but have no clue if it got messed up or what. Quick Googling of those terms doesn't seems to yield much help so I really appreciate all the help I can get here. Let me know if there's any more info I can provide to help figure this out. Attachment 447173
