Need Help! HSM Linear problem
Results 1 to 2 of 2
Thread: HSM Linear problem
    Member Alexpaintkiller's Avatar
    Jul 2019
    Default HSM Linear problem
    i use the HSM Linear Operation for a specific part and i have celected all the faces i want ( picture ) and i use stepover 5.2mm but it keeps the same line of pass for all the different faces as it is in the picture . but the faces i have sellected have a zig-zag patern so as the operation uses the same"line; i find mi self haveing different passes on the left surfaces than on the right surfaces . hope the pictures help
    is there a way to have different stepovers etc for every one of these geometries ? i use SOLIDCAM 2018
    Attached Thumbnails Attached Thumbnails HSM Linear problem-capture3-jpg   HSM Linear problem-capture-jpg   HSM Linear problem-inkedcapture2_li-jpg
    Member offsets's Avatar
    Nov 2012
    romania
    Default Re: HSM Linear problem
    Quote Originally Posted by Alexpaintkiller View Post
    use only for 3D shape liniar.....in your case only 2D strategies!SIMPLY!
HSM Linear problem
HSM Linear problem
