Post processor for Solidcam
Results 1 to 2 of 2
Thread: Post processor for Solidcam
    Default Post processor for Solidcam
    Hi guys!
    I've ran into a nasty post processor problem when doing 4th axis machining with solidcam. I suspect the problem lies within @usr_rapid code. (see below)
    Post processor for Solidcam-gcode-problem-jpg
    The post processor generated multiple A axis movements in the same line. This happens for G00 rapid movement only.
    For G01 movements the post processor sometimes generates unnecessary A axis movements, for example lines N362 and N364.
    The code for @usr_rapid:
    Code:
    @usr_rapid
        ; Handle output for Rapid Move (G00)
        ; Note: XYZ not allowed together on a single line
        ; ---- 4x
        ;   - Set Rotary Position
        call @usr_r1pos_calc
        if !bSkipxyrapid
            if change(apos) and !change(xmpos) and !change(ympos) and !change(zmpos) and !change(bpos) ;Ignore apos prepositioning, handled at toolchange
                skipline = false
            endif
            if bCoolspinaftertc and bTlchg
                skipline = true
                call @start_tool
                if bCoolExist
                    skipline = true
                    call @usr_coolant
                endif
            endif
            if !bSyncdrapid
                if job_type eq '3-d model'
                    iMotionmode = 1
                else
                    iMotionmode = 0
                endif
            else
                iMotionmode = 0
            endif
            if (change(xmpos)or change(ympos)) and change(zmpos) ;!@#$% clear change
                bTest = true
            endif
            {nb,['G'iMotionmode:mcode_f ' '],['G'iMplane' '],[cWo,iWorkoffset' '],['G'iAbsincmode ' '],['X'xmpos ' '],['Y'ympos ' '],[cR1,nR1pos ' '],[cR2,nR2pos ' ']}
            if change(zmpos)
                ;if change(xmpos) eq true or change(ympos) eq true
                if bTlchg
                    if !bCoolspinaftertc
                        skipline = false
                        call @start_tool
                        if !bHeightComponToolCh
                            call @usr_heightcomp_on
                            {'Z'zmnext_start_tool_level ' '}
                        endif
                        if bCoolExist
                            if !bCoolAfterHeightComp
                                skipline = false
                            endif
                            call @usr_coolant
                            skipline = true          ;!@#$%AC Incase no coolant output, need to override 'skipline = false' 3 lines above
                        endif
                    else
                            skipline = false
                        endif
                    endif
                else
                    if bTest  ;!@#$% clear change
                        {nb,['Z'zmpos ' ']}
                        bTest = false
                    else
                        {['Z'zmpos ' ']}
                    endif
                endif
            endif
            if !bSyncdrapid
                    {['F'nRapidfeed' ']}
                endif
            endif
            bSkipxyrapid = false
        else
            {nb,['Z'zmpos ' ']}
            if !bSyncdrapid
                endif
            endif
        endif
        if bTlchg
            if bCoolExist
                skipline = false
                call @usr_coolant
            endif
        endif
        if change(iMotionmode)
            change(iMotionmode) = false
        endif
        if change(iMplane)
            change(iMplane) = false
        endif
        if change(iWorkoffset)
            change(iWorkoffset) = false
        endif
        if change(iAbsincmode)
            change(iAbsincmode) = false
        endif
        if change(nRapidfeed)
            change(nRapidfeed) = false
        endif
        if !bSyncdrapid
            bFeedoutput        = true
        endif
        change(cWo) = FALSE ;!@#$%AC Fix for ChangeBit Intermittent problem
        if bMultiplefixtures and bTlchg
            mltfixxmpos = xmpos
            mltfixympos = ympos
            mltfixzmpos = zmpos
            bFromendchangetool = True
            call @Multiple_Fixtures
        endif
        bTlchg = false
        bfirst_rapid = false
        skipline = true
        bTest = false
    endp
    The post processor is for a 5 axis machine(CNC Router + 2 axis rotary table). Post processor has been downloaded from this forum if I'm not mistaken.
    I must mention that I have little knowledge in programming and let alone in post processor programming.
    If someone has any fix for this I'd be very greatful.
    Attached Thumbnails Attached Thumbnails Post processor for Solidcam-gcode-problem-jpg
    Default Re: Post processor for Solidcam
    Never mind! I seem to have fixed it by myself.
