Need Help! Limit stepover in 2.5D pocket milling
Results 1 to 2 of 2
Thread: Limit stepover in 2.5D pocket milling
    Aug 2016
    United Kingdom
    Default Limit stepover in 2.5D pocket milling
    I'm sure the answer's simple but i can't find a way of setting a maximum to the tool step-over in a 2.5D pocket milling operation. There is the ability to set a minimum but i want to take gentler cuts than this provides. In my example i'm using a 8mm ball ended mill and i want to step it over in 2mm increments but with the settings in "Technology" it steps over 4mm.
    May 2013
    Croatia
    Default Re: Limit stepover in 2.5D pocket milling
    Take a look at screenshot
    Attached Thumbnails Attached Thumbnails Limit stepover in 2.5D pocket milling-clipboard01-jpg
    admin
    Guest
    Default ?????????? ???????
    ?????? ????! ????? ?????????? ??????? ?? ???? ?????: http://limonos.ru : ??????? ??????????? http://limonos.ru/arhitektura/ ???????? ?????? ??????? ???? http://limonos.ru/priroda_foto/ http://limonos.ru/8367-novosibirsk-s-vysoty-2017.html ??????????? ? ?????? 2017 ?????????? ???????? ? Harper's Bazaar Arabia ?????????? ???????? ? Harper's Bazaar Arabia http://limonos.ru/9006-sovok-v-shotlandii.html
